Bug - Path String
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Jan 14, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I took the project variable and put a path to a folder in it. When I used it had changed as follows.
    The original: C:\ProgramData\3CX\Data\Work Order Audio
    Changed to: C:programDataCXDataWork Order Audio
    After I escaped the backslash '\\' it worked. I can't imagine too many non-programmers would think to try that.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    If you're using a string with quotes, then you need to escape special characters. The string you enter is a javascript expression, so you need to escape characters as backslash, quotes, etc. This is not a bug, this is by design.
    Maybe we should offer a button or something to quicly enter a string literal, and then we escape it for you. But the string that will be entered as value for the expression will have the escaping characters.
    Regards,
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Maybe even validate string literals for special characters when the text box control loses focus.
  4. VAD_Support
    Aug 6, 2009
    690
    The problem is that you may want to add some special character. For example, you may want a TAB, and then enter \t, but if we escape that automatically, that would become \\t, and that's not what the user wanted originally. So, in order to enter a string literal, we could offer a dialog to enter it, but the user would have to say "I want a string literal", and then we escape it automatically. We cannot do that in every case without asking the user...
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Maybe pop up the dialog if you detect a special character?
  6. VAD_Support
    Aug 6, 2009
    690
    I'm thinking on a toggle button on the right of each text box. Something like the button to show or hide characters in a password text box (you can see that in the admin interface of 3CX). When it's pressed, the user enters a string literal, and when it's not pressed, the user enters an expression.
    We need to discuss the best metaphor to use, and then implement the change...
