Bug Report: 3CX Client missing from System Tray
Discussion in 'Windows' started by darrellchapman, Feb 8, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    When I minimize the 3CX VoIP client, it correctly minimizes to the task bar and when I click the X for exit it correctly minimizes to the system tray. However sometimes when it minimizes to the system tray, no icon is shown in the system tray. The program is still running (verified in the Task Manager-->Processes) however there is no way to get the 3CX client back up. The only way to get the icon back is to kill the 3CXVoIPClient.exe process and restart the 3CX client.
    Has anyone else experienced this?
    OS: Windows XP Pro x86 SP2
    Darrell Chapman
  2. darrellchapman
    Nov 26, 2007
    268
    As far as I can tell, this bug has been fixed in build 4132.
    Darrell Chapman
