Bug Report: Attended Transfer to VoIP Client (4132) Fails
Discussion in 'Windows' started by darrellchapman, Feb 28, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    Has any noticed this or found a solution to this problem?
    When transferring a call (any call), to the VoIP Client via attended transfer, the call fails. If I initiate the transfer, I can successfully talk to the destination, however when I attempt to transfer my on-hold caller to them, it fails. The caller remains on hold and they are never joined.
    If I were to perform the same attended transfer to a desk phone, the transfer succeeds. Also, blind transfers are working correctly for both desk phones and 3CX VoIP Client.
    Any advice?
    Thanks,
    Darrell Chapman
  2. mc2
    mc2
    Apr 6, 2009
    17
    Hi Darrell
    We are having the same issue even after upgrading both clients and system to the latest versions. Did you ever get a fix for this?
    thanks
  3. darrellchapman
    Nov 26, 2007
    268
    I don't believe we have this problem any more. We've upgraded three or four times since my original post.
