Bug Report (build 4132): Client Not Connecting
Discussion in 'Windows' started by darrellchapman, Feb 26, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    A bug in the VoIP Client that was brought to our attention today: If a computer should lose it's network connection, the VoIP client makes no attempt to log back in to 3CX when the network connection is restored. You have to manually tell the client to log back in before the client is active again. However, the client still continues to see the correct status of all of the other extensions upon network restore.
    Darrell Chapman
