Bug Report: Internal Client Caller ID
Discussion in 'Windows' started by darrellchapman, Feb 18, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    Shouldn't the 3CX Client be using the customized outbound caller ID field from the 3CX server for internal client rather than just the extension number? For larger deployments (like ours), I'd like to know who extension 271 is instead having to look it up on the extension list.
    Darrell Chapman
    I'm editing this post because I've confirmed that this is a bug in the client.
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Re: Internal Client Caller ID
    Which version are you using. I am using 5.1.4132.0 and this correctly displays the Outbound caller ID as set in 3CX
    Stephen
  3. darrellchapman
    Nov 26, 2007
    268
    Wardy,
    All clients are using v5.1.4132.0 and it's showing only the extension number in both headset and desk phone modes.
  4. darrellchapman
    Nov 26, 2007
    268
    One more thing: All of the desk phones are showing correct Outgoing CallerID info. Its only the 3CX Client.
  5. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Yes mine does the same that way too
    Stephen
