BUG: SMTP server specified as host.or.ip:port fails in v9
Discussion in '3CX Phone System - General' started by carolinainnovative, Jul 1, 2010.
  1. carolinainnovative
    May 4, 2009
    369
    6
    See: http://www.3cx.com/forums/smtp-issues-15805.html
    Discovered by packetwire_59 - confirmed it is an issue with mine as well.
    When one specifies an smtp server in Settings->General->Mail server as host.domain.tld:port or ip.addr.of.mx:port and then does something to generate an email (like, for example, send a welcome email) one gets the following error:
    An exception occred Error: Failure Sending Mail
    The remote name could not be resolved: host.domain.tld:port
    Nothing shows in the server logs.
    I am running 9 beta 2. packetwire_59 did not specify which beta he is running - just that he is running a version 9 beta.
    Enjoy!
  2. packetwire_59
    Jun 30, 2010
    25
    Thanks for reporting this Salter. I am running version 9 build 13011.
  3. carolinainnovative
    May 4, 2009
    369
    6
    This is still an issue in V9 RC1
  4. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    confirmed bug
    thanks for reporting
  5. intac
    Mar 29, 2010
    7
    I am having the same problem in V2 has anyone found a fix yet?
  6. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    This issue is fixed in 3cxphone system v9 with sp2
    Check the voicemail logs and see what they say - you can paste them here. Maybe mail server is not being authenticated or not reachable
  7. intac
    Mar 29, 2010
    7
    Well i encountered this in trying to receive a fax and sending the fax to an email address. I first noticed that the fax was received but the email was not being forwarded. So i then went into the console and tried to send a welcome letter and i kept getting this error
    Unable to read data from the transport connection: net_io_connectionclosed
    I dont think the vm logs will help me here, what other logs do you think i may check?
  8. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    You do not have a healthy connection to your mail server. Or vice versa.
    Can you telnet ur mail server and port from the pbx machine?
    If you want to confirm this forward mail server to google for example and see if the mail is received.
    The bug in this case was only when the smtp server was listening on a non default port - ie something other than 25. This is a different problem. Try and run telnet IPSMTPSERVER PORT and see what you get.
