BUG: Time in MyPhone always 24hr Format**CONFIRMED FIX
Discussion in '3CX Phone System - General' started by KerryG, Mar 21, 2011.
  1. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Even though my system's time is set to 12 hour format, the clock in the MyPhone interface always shows it in 24 Hour format.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    170
    Re: BUG: Time display in MyPhone always 24 Hour Format
    noted - thanks for reporting.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    170
    is fixed already - will be available in the next update
    Thanks for feedback.
  4. itet
    Jun 29, 2010
    Ok, but my prolbem is, that I haven't ever seen the 24hr format. In MyPhone I can only see 12hr format. My version is the last RC v10 and I use German language.
