BUG: Webclient click to call
Discussion in '3CX Phone System - General' started by Brad Cann, Oct 4, 2017.
  1. Brad Cann
    Brad Cann New Member
    May 5, 2017
    111
    16
    Gday All,
    I was just playing around with click to call plugin, and we wanted to append a 0 to the front of the number to get an outside line, which doesn't seem like it is possible, but this isn't the bug, when we tried to change the number anywhere in the webclient click to call window you can't insert a number midway or anywhere through the number, it only adds it to the end of the number.
    So For instance:
    click to call number:
    0288888888
    say we wanted to change one of the 8's to a 7 or any other number IE (0288887888)
    in click to call webclient window it would wind up even if i moved the cursor to the correct location it would place the 7 at the end IE 02888888887
    It would also be good if the webclient click to call would follow windows TAPI and prepend a 0 to the number so we can get an outside line, as it is now with this existing bug the click to call webclient is useless as you can't even manually append the 0 in front of the number.
