Bug when shutting down server?
Discussion in 'Windows' started by MojoDK, Sep 27, 2010.
  1. MojoDK
    Sep 22, 2010
    26
    Hi all,
    (using latest beta)
    When I shut down the server, 3CXPhone still have all softkeys enabled - it also says "On Hook" even thought the server is down. If I try to make a call, it just rings.
    Doesn't Voip Phone "see" that server is down?
    Mojo
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,494
    67
    Hi Mojo
    Thanks for spotting it 8) Indeed, it might be considered a bug - and we will fix it - because 3CXPhone should assume if it doesn't receive presence information in the time interval negotiated with the PBX, BLF status should become unknown. (Voip client doesn't know its server is down, it doesn't perform "network ping" - for flooding reasons - so it only knows it get a timeout, which we should handle properly)
    vali
