- Joined
- Jan 21, 2016
- Messages
- 7
- Reaction score
- 0
I think I've found a bug...
It looks like when you add a new sip trunk, if you specify a duplicate number, it only checks the port identification field and not the authentication id field.
Basically, I create a new sip trunk, typed a number and it went to the next page, but then I got an error saying "An exception occurred EditVoipProvider Error: Object reference not set to an instance of an object". and it repeated this error if I selected the VOIP provider.
If I change the port identification to match the authentication id, this does not occur as I get a friendly error telling me that I can't have a duplicate number.
FYI... I was trying to add two sip providers in a cluster by their actual IP instead of the cluster ip... so the same number can come from both machines... Guess I can't do it this way!
