- Joined
- Aug 7, 2011
- Messages
- 7
- Reaction score
- 0
Hello everybody !!!!!!
I use 3CXphone system V10 SP3 with a linksys SPA3102 gateway.
To phone i use 3cxphone for windows V6 and 3cxphone for android.With the 1.3.1 everything was OK.
Now with the 1.3.2 I cannot use the spa3102 access from the 3cxphone android.
Here is the log with android access:
14:40:54.875 [CM504002]: Ext.14: a contact is unregistered. Contact(s): []
14:36:06.640 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server [ V4 96.9.132.83:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 192.168.0.2:5060 UDP target domain=unspecified mFlowKey=0 ]
14:35:16.937 [CM503016]: Call(12): Attempt to reach <sip:%230**[email protected]:5060> failed. Reason: Not Acceptable HereReason Unknown
14:35:16.921 [CM503003]: Call(12): Call to sip:**[email protected]:5060 has failed; Cause: 488 Not Acceptable Here; warning: Media type not available; from IP:192.168.0.1:5060
14:35:16.890 [CM503025]: Call(12): Calling PSTNline:**1@(Ln.10002@SPA3102)@[Dev:sip:[email protected]:5060]
14:35:16.843 [CM503004]: Call(12): Route 1: PSTNline:**1@(Ln.10002@SPA3102)@[Dev:sip:[email protected]:5060]
14:35:16.843 [CM503010]: Making route(s) to <sip:%230**[email protected]:5060>
14:35:16.828 [CM505001]: Ext.14: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Android 1.3.2] PBX contact: [sip:[email protected]:5060]
14:35:16.828 [CM503001]: Call(12): Incoming call from Ext.14 to <sip:%230**[email protected]:5060>
14:35:09.671 [CM504001]: Ext.14: new contact is registered. Contact(s): [sip:[email protected]:5060;ob/14]
And here is the log with the 3cxphone for windows which runs fine:
14:47:19.484 [CM503008]: Call(13): Call is terminated
14:47:11.093 Currently active calls - 1: [13]
14:47:10.953 [CM503007]: Call(13): Device joined: sip:[email protected]:5060
14:47:10.953 [CM503007]: Call(13): Device joined: sip:[email protected]:60844;rinstance=3a662215eed80766
14:47:10.906 [CM505002]: Gateway:[SPA3102] Device info: Device Identified: [Man: Linksys;Mod: SPA series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:[email protected]:5060]
14:47:10.906 [CM503002]: Call(13): Alerting sip:[email protected]:5060
14:47:10.843 [CM503025]: Call(13): Calling PSTNline:**1@(Ln.10002@SPA3102)@[Dev:sip:[email protected]:5060]
14:47:10.812 [CM503004]: Call(13): Route 1: PSTNline:**1@(Ln.10002@SPA3102)@[Dev:sip:[email protected]:5060]
14:47:10.796 [CM503010]: Making route(s) to <sip:%230**[email protected]:5060>
14:47:10.796 [CM505001]: Ext.13: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.19548.0] PBX contact: [sip:[email protected]:5060]
14:47:10.781 [CM503001]: Call(13): Incoming call from Ext.13 to <sip:%230**[email protected]:5060>
14:47:01.562 [CM504001]: Ext.13: new contact is registered. Contact(s): [sip:[email protected]:60844;rinstance=3a662215eed80766/13]
Do you know where i can download the prior version 1.3.1 ??????
Thanks a lot for your help
