Bug:? Wrong IP sent in Contact Field
Discussion in '3CX Phone System - General' started by abc123, Apr 9, 2011.
  1. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    We have static ips with 1:1 Nat and so have a dedicated ip and and static port forwarding on our 3cx server. All works correctly.
    In the Networking section we have turned off Stun and put in our public ip. In each voip provider we have also turned off stun and put in our public ip.
    When we register the correct public ip is being sent. But when we send an invite the internal ip is being sent.
    Sidenote: I believe the registration contact ip is picked up from the voip provider settings but the invite contact ip is picked up from the STUN tab in the Network settings.
    Can you confirm this is a bug?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Can you send a generate support info of this? Or a capture?
    What provider are you using?
    Can you try and restart all the services and try again (could be a cache problem where changes were made on the fly and the pbx kept on sending that internal address in the contact.)
  3. abc123
    Nov 9, 2009
    712
    Sorry for the delay in reply.
    The problem fixed itself.
    We had 3 providers - 2 broadvox and our own sip service we are launching. All 3 did the same. I restarted services with no change, rebooted the server with no change then (possibly on next registration) about 40ish minutes later it changed.
