Bug - Yealink Always Forward breaks hunt group
Discussion in '3CX Phone System - General' started by tim942, Sep 3, 2015.
  1. tim942
    Jul 30, 2015
    68
    6
    All,
    I just found a bug where using the always forward feature on the Yealink phone overrides a hunt group and sends it to the voicemail of the forward. I would have expected that the hunt group process would see the "Cause: 302 Moved Temporarily/INVITE" message and move on to the next but apparently not.
    This is on the new v14.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Yes that is correct, forwarding should be implemented on the extensions forwarding rules and profile switched when necessary from a BLF for example, rather than using 302 redirections from the phone.
  3. tim942
    Jul 30, 2015
    68
    6
    We're coming from an antique Nortel system where my users are used to doing everything at the phone level, so I will work on the BLF option. This would not be a real issue, but one phone will have multiple accounts, the transfer button on the phone seemed like a good chance.
