Bug?
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Sep 20, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    My component build fine, but after deploying it IIS6 had a problem compiling it.
    Attached is a screen shot of the config for the given database component
    Event code: 3007
    Event message: A compilation error has occurred.
    Event time: 9/19/2009 11:10:42 PM
    Event time (UTC): 9/20/2009 5:10:42 AM
    Event ID: e2562709944f493b8b5c7235f95bb290
    Event sequence: 199
    Event occurrence: 2
    Event detail code: 0
    Application information:
    Application domain: /LM/W3SVC/2/ROOT-2-128978968599375000
    Trust level: Full
    Application Virtual Path: /
    Application Path: C:\Documents and Settings\All Users.WINDOWS\Application Data\3CX\Data\Http\Interface\ivr\
    Machine name: TFS2
    Process information:
    Process ID: 4928
    Process name: w3wp.exe
    Account name: NT AUTHORITY\SYSTEM
    Exception information:
    Exception type: HttpCompileException
    Exception message: c:\Documents and Settings\All Users.WINDOWS\Application Data\3CX\Data\Http\Interface\ivr\CellsAgent_Debug_52\Main_MF_databaseAccessComponent1_DoIt.aspx(134): error CS1010: Newline in constant
    Request information:
    Request URL: http://localhost:5484/CellsAgent_Debug_52/Main_MF_databaseAccessComponent1_DoIt.aspx?dataSource=&database=cellsagent.com&parameterCount=1&parameter_0=100650&password=8Trh76&server=TFS2e2562709944f493b8b5c7235f95bb290CSQLEXPRESS&userName=cellsagent.com
    Request path: /CellsAgent_Debug_52/Main_MF_databaseAccessComponent1_DoIt.aspx
    User host address: 127.0.0.1
    User:
    Is authenticated: False
    Authentication Type:
    Thread account name: NT AUTHORITY\SYSTEM
    Thread information:
    Thread ID: 1
    Is impersonating: False
    Stack trace: at System.Web.Compilation.BuildManager.PostProcessFoundBuildResult(BuildResult result, Boolean keyFromVPP, VirtualPath virtualPath)
    at System.Web.Compilation.BuildManager.GetBuildResultFromCacheInternal(String cacheKey, Boolean keyFromVPP, VirtualPath virtualPath, Int64 hashCode)
    at System.Web.Compilation.BuildManager.GetVPathBuildResultFromCacheInternal(VirtualPath virtualPath)
    at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
    at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
    at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
    at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
    at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
    at System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFactory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
    at System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig)
    at System.Web.HttpApplication.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
    at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
    Custom event details:
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi, this is probably a bug, can you provide us the file Main_MF_databaseAccessComponent1_DoIt.aspx where it is reporting it? Please, remove from it any sensitive information... Or just post here the line 134 (the one with the error).
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    This problem happened when I put the explicit value for the parameter instead of a callflow variable.
    Here's the line from the code. Looks like the problem is that it broke up the code into two lines for some reason.
    string sqlStatement = String.Format("select PHONE from PROPERTYLISTINGS
    where PROPERTYCODESID = {0}", args);
  4. VAD_Support
    Aug 6, 2009
    690
    OK, we'll check this.
    Maybe you entered a ENTER character in the SQL statement text. Can you remove that new line from there and see if the error goes away?
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Yes, it was the carriage return (ENTER character).
    It seems to me that should be made valid to put as SQL syntax.
  6. VAD_Support
    Aug 6, 2009
    690
    Absolutely, this is a bug that we'll fix in the next release.
    Thanks for noticing about this.
