Build 3790 Authentication Failed
Discussion in '3CX Phone System - General' started by bs_yellowbox, Feb 6, 2008.
  1. bs_yellowbox
    Feb 5, 2008
    After a restart from our 3CX all password seems lost, is this a know bug? Or ...
    We must then reset all passwords for a extensions and after that they can register again.
    [CM102001]: Authentication failed for SipReq: REGISTER voip.xxxxx.xx tid=4EA7B56FC1DB968F cseq=REGISTER contact=32052@xx.xx.xxx.160:5060 / 7 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Thanks for your post.
    Have you performed a restore or similar? If so was the restore of a backup or a restore of the support info?
    If you restored support info then passwords would not be in there.
    There is currently no known issue of passwords being lost at this stage. If you could give us more info on what triggered the issue we can look into.
