Build 4492 Problem
Discussion in 'Windows' started by darrellchapman, Apr 17, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    3CX Team,
    As others have stated in these forums, build 4492 has broken the status functionality in the client. I'm going to go out on a limb here an assume that it's because it requires build 4492 of the server. If this is the case then you should either specify that in your announcement about build 4492 or simply don't make it available until the server is available.
    I'm very disappointed that I've just deployed this to a couple of workstations and must now go back and locate a copy of 4393 just to get status working again.
    Please advise.
  2. SWB
    SWB New Member
    Mar 26, 2008
    136
    Yep same issue I reported in my thread. Luckily I had a client 4393 install on a server I could use so ok.
