Build v806 wont install on a Windows 2003 x64 server
Discussion in '3CX Phone System - General' started by bcampbell74, Aug 24, 2008.
  1. bcampbell74
    Jan 17, 2008
    50
    I receive the installation error 2755 whilst trying to install build v806. The host PC is a HP Proliant ML115 running Windows 2003 R2 x64 server. It will install and run the previous version 5 software just fine. Any Ideas?
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Can you post the exact error message you are getting during this installation?
  3. bcampbell74
    Jan 17, 2008
    50
    I shall attempt to reinstall tomorrow evening as I am out all day today and 3CX is in use during business hours. Will put a screen grab up of the exact error and point during installtion. If there is anything else you would like me to include please let me know.
  4. bcampbell74
    Jan 17, 2008
    50
    Sorry it has taken me a while to get back around to this. Any help would be much appreciated. Installer log attached.
  5. bcampbell74
    Jan 17, 2008
    50
    I have just noted I have posted the wrong build on my posting. This should read v6.173.
