Bulk Delete Voicemails in 3CXPhone for Windows
Discussion in 'Ideas' started by mertoman, Mar 22, 2016.
  1. mertoman
    Mar 7, 2016
    I think you should enable bulk delete for Voicemails in the 3CXPhone for Windows v14 app. In Missed Calls I can hold down the Shift Key, highlight the first and last call then press delete. Let's do this in Voicemails, also.
    Regards,
    John Schmidt
    IT Mgr | Fox Lumber Sales, Inc.
    www.foxlumber.com
    john@foxlumber.com
