Bulk Edit of Extensions SP2
Discussion in '3CX Phone System - General' started by JStellato, Oct 14, 2016.
  1. JStellato
    Dec 17, 2015
    34
    6
    How do we bulk edit extensions in SP2?
    CTRL + Click to select multiple extensions, and then click the edit button just brings up the first selected extension.
  2. norekhov
    3CX Support
    Jan 31, 2014
    53
    Yes, you're right. Select with "Ctrl" and then press "Edit". It edits all extensions.
    Probably you occasionally removed multiselect somehow.
  3. wtrbhe
    Oct 9, 2015
    22
    Looks like it only works with Chrome (54.0.2840.59) and only with ctrl-key, selecting a list by by clicking first and last line while holding shift-key won't work.
    Using Firefox (49.0.1) or Edge (38.14393.0.0) won't work for bulk-edit.
  4. JStellato
    Dec 17, 2015
    34
    6
    Ok yes, I just checked this is does not work in FireFox 49. That's where my confusion is. It does work in Chrome with the CTRL key, but oh my goodness can we change the highlight contrast????
    It's almost impossible to see it.
  5. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Another thing is you'll need to clear the browser cache after updating to SP2 for this to work.
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Or press refresh. Works on all supported browsers.
    Can you confirm by refreshing the page or better clearing the cache, you can multi-edit?
  7. JStellato
    Dec 17, 2015
    34
    6
    I can confirm it works 50% of the time, every time.
    Half the problem is you can't see which extensions are highlighted because the contrast between selected and unselected is so awful.
