Solved Bulk phonenumbers to each extension? (Inbound rules?)
Discussion in '3CX Phone System - General' started by MSmeets, Oct 29, 2017.
  1. MSmeets
    Sep 25, 2017
    32
    I am sure this question must be asked before, but I can not find the answer .
    I find a lot of information about inbound rules but do not have a clue how to implement.
    Question:
    I have 100 phonenumbers.
    first: 010-22222200
    last: 010-22222299
    the 00 is the main number
    I want 01 to be connected with extension 001
    I want 02 to be connected with extension 002
    etc etc
    I can create 100 Inbound Rules with DID...but that would be stupid, must be another way , simple way?
    Anyone?
  2. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    106
    38
    That's how. No, you can't csv import dids to a trunk or inbound rules.
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Why not able to import .csv file with all 100 numbers ?
    It is very easy to create such file in Excel for example.
    YiannisH_3CX likes this.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @MSmeets
    As @sip.bg mentioned you can import a csv file under the Inbound rules which will add the DIDs under the trunk. I would recommend creating an Inbound rule manually and exporting that so you get the correct format for your import.
  5. MSmeets
    Sep 25, 2017
    32
    Thank everyone!
    case closed :)
