Bulk Update Extensions v15
Discussion in '3CX Phone System - General' started by zcsjfisher, Nov 9, 2016.
  1. zcsjfisher
    Nov 9, 2016
    We recently installed 3cx, and I am needing to update many of our phones with a new custom template and also want to bulk update our Outbound Caller ID for the phones as well. I have exported the csv of the current extensions and have edited the csv. Can I import this back in? From what I have read, it seems I would have to delete all the extensions then import them in again? Wouldn't all of my users lose their voicemails and all of that if I had to do so?
    I can't seem to do what I want by CTRL+Clicking multiple extensions as I have over 400 phones and I really don't want to have to do this one by one.
    Any feedback would be appreciated! Thanks.
  2. bboydewil
    Jan 20, 2017
    18
    Have you found solution? We need to update settings against all agents in queue (disable push) and I am trying to find bulk function or access to db. Obviously, same as you - not by export -> delete -> import. Thank you.
  3. relion
    Nov 8, 2014
    10
    Same issue here. We need to bulk update extensions. Anyone found a work-around?
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,350
    451
    Hello @relion
    Have you tried holding down the ctrl key and selecting multiple extensions? What version and service pack are you running? You should be able to select multiple extensions in V15 sp2 onwards
    bboydewil likes this.
  5. bboydewil
    Jan 20, 2017
    18
    thanks heaps, this now solves my problem of updating PUSH notification on multiple extensions. well done guys!
