Busy Lamp Field - BLF
Discussion in '3CX Phone System - General' started by nateb, Nov 13, 2007.
  1. nateb
    Oct 19, 2007
    68
    Does 3CX Support Busy Lamp Field (BLF) ?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    What kind of BLF support are you expecting from 3CX PBX?
  3. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    If you are looking at checking the state of some extension, eg ringing or busy then this will work for Snoms and Grandstreams
  4. federicom
    Oct 24, 2007
    16
    When it will works with linksys, for example with LINKSYS SPA962 + SPA932(new BLF module ?) Thank you.
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We just didn't test it with linksys. If Linksys properly uses dialog-info for it - it sould work.
  6. nateb
    Oct 19, 2007
    68
    busy lamp field
    the functionality I am looking for would just be who is on what line. So if ext 101, is talking to somone, and i have a button for them, it would show them on the phone. I am using grandstream 2000 and 2020 phones.
    What version is this supported in? and can you point me in the direction to configure it?
  7. archie
    3CX Support
    Aug 18, 2006
    1,299
    We have a bug in build 3287 which prevents correct work of BLF with Grandstreams. The build we have now in QA has this bug fixed, and GXP-2020 works just great. For GXP-2000 you need to have latest firmware installed, as far as I know.
    Re configuration - simple search in inet will give you tons of samples how to configure it for asterisk. You don't need to configure anything on 3CX PBX side, so just use those samles as a hint how to configure a phone.
  8. nateb
    Oct 19, 2007
    68
    version
    so what version supports it?
  9. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i have takesome looks in the inet for config 2020 for BLF but i read here first time that i canput inthe same then is asterisk! best is to but a note in the tech manual?
    thx
    andy
  10. nateb
    Oct 19, 2007
    68
    update?
    So, I don't really know that anyone has addressed this? Is this a feature of the phone? or the Sip Server? If someone, can somone help me configure this?
  11. silentfun
    silentfun Member
    Dec 11, 2006
    364
    it is a feature of the phone (indicateing a busy line/extension) but it need info from the pbx i think - and i have no info about to config this
