Solved Busy Light integration...
Discussion in 'CRM / Helpdesk / App Integration' started by dcnigma, May 11, 2017.
  1. dcnigma
    May 10, 2017
    Hey All,
    I am trying to integrate busy Light for 3CX but i am not that good in C#
    Want to change the the light colour if there is a call or the person available.
    Got it working partially but i have some trouble reading the status of the 3CX.
    Here is the code i written:
    Code:
    using BusylightTester;
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    using System.Threading.Tasks;
    using System.Windows.Forms;
    using System.IO;
    using MyPhonePlugins;
    namespace MyCRMPlugins
        [CRMPluginLoader]
        public class MyCrmPlugin
            private static MyCrmPlugin _instance;
            private static IMyPhoneCallHandler _callHandler;
            private Busylight.SDK busylight = null;
            [CRMPluginInitializer]
            public static void Loader(IMyPhoneCallHandler callHandler)
    //show busylight form
                frmMain frm = new frmMain();
                frm.Show();
                _instance = new MyCrmPlugin(callHandler);
            public MyCrmPlugin(IMyPhoneCallHandler callHandler)
                _callHandler = callHandler;
                _callHandler.OnCallStatusChanged += CallHandlerOnOnCallStatusChanged;
                _callHandler.OnMyPhoneStatusChanged += CallHandlerOnOnMyPhoneStatusChanged;
            private void CallHandlerOnOnMyPhoneStatusChanged(object sender, MyPhoneStatus status)
                frm.busylight.Light(Busylight.BusylightColor.Green);
            private void CallHandlerOnOnCallStatusChanged(object sender, CallStatus callInfo)
                frm.busylight.Light(Busylight.BusylightColor.Red);
            private void callhandler_OnCallStatusChanged(object sender, CallStatus callInfo)
            public CallStatus MakeCall(string destination)
                return _callHandler.MakeCall(destination);
    Hope you guys can help me :)
    Thanks in advance
    mortenjorge likes this.
  2. Andreas Paradisiotis
    Apr 7, 2017
    53
    12
    Hello dcnigma
    In method CallHandlerOnOnCallStatusChanged there is a parameter callInfo of type CallStatus.
    callInfo.State is going to give the current status of client
    Here is CallState enum
    public enum CallState
    Undefined,
    Ringing,
    Dialing,
    Connected,
    WaitingForNewParty,
    TryingToTransfer,
    Ended,
    So you need to get the status and based on the status change the color accordingly
    Example
    if (callInfo.State == CallState.Connected)
    dcnigma likes this.
  3. dcnigma
    May 10, 2017
    Hey Andreas,
    that is the solution in needed, a super thank you for you :D
  4. dcnigma
    May 10, 2017
    #4 dcnigma, May 11, 2017
    jub, mortenjorge and StefanW like this.
  5. fas
    fas
    Mar 9, 2009
    6
    Hi I have the 3CX Phone 15.5.1694.0 on my Windows 10 Laptop and I extracted and copied all in the Folder you described. Then I rebooted the Laptop. I did not install any Software from bizylight at all. And I also did not edit any files. What I make wrong, because the Bizylight does not work at all. It's really all, just copying the files and it should work? Or did I misunderstand something?
    Thanks for your help
    Mario
  6. fas
    fas
    Mar 9, 2009
    6
    o.k. I got it. I did copy all in the Folder first, but I had only to copy the files in “/Release/Copy 2 3CXphone” in the 3CXPhone folder. Actually, I did not copy the 3CXWin8Phone.user.config file. I edited it by myself and added "MyCRMPlugin" in the “key="CRMPlugin"” string because we had more active plugins then you had in your example. Now it works perfect. Thanks for your work!
  7. mtnsms
    Aug 16, 2017
    @dcnigma: thank you for sharing the plugin. it works fine!
