Busy sound feedback by system, when Busy
Discussion in 'Ideas' started by DovydasJ, Dec 13, 2016.
  1. DovydasJ
    Nov 17, 2015
    17
    13
    Simple and usefull feature:
    When I'am calling from my extension (A) to external number (B) and I got system answer:
    1. When B side is already talking with someone else: Call failed, Busy
    2. When B side do not answer the call in x seconds: Call failed, Busy
    ... after that PBX system could give feedback for the caller (A) about that trying with simple "beep beep beep" sound.
    Thanks, bye!
    10,763
    286
    If you are referring to the recording that you receive from 3CX, when reaching a busy external call (on a SIP trunk), rather than a busy tone, this can be changed in the PBX options. Under Custom parameters...Busyprompt change to 0 will give a busy signal rather than the message.
