But for calls through fxs do not work
Discussion in '3CX Phone System - General' started by pepe75, Oct 10, 2007.
  1. pepe75
    Sep 18, 2007
    With himself not to make work spa 3102
    Somebody podria to help me with the configuration for Spain
    the problem is that the calls by supplier voip if works, but for calls through fxs do not work
    19:33:42.468 StratLink::eek:nHangUp [CM104001] Call(116): Ext.104 hung up call; cause: BYE; from IP:192.168.1.10
    19:31:19.182 CallLegImpl::eek:nConnected [CM103001] Call(116): Created audio channel for Ln:10000@spa 3102 (192.168.1.1:16438) with Media Server (192.168.1.10:7468)
    19:31:19.152 StratInOut::eek:nConnected [CM104005] Call(116): Setup completed for call from Ext.104 to Ln:10000@spa 3102
    19:31:19.152 CallLegImpl::eek:nConnected [CM103001] Call(116): Created audio channel for Ext.104 (192.168.1.10:2409) with Media Server (192.168.1.10:7466)
    19:31:19.132 CallConf::eek:nProvisional [CM103003] Call(116): Ln:10000@spa 3102 is ringing
    19:31:18.792 CallConf::eek:nIncoming [CM103002] Call(116): Incoming call from 104 (Ext.104) to sip:955999837@192.168.1.10
    19:31:14.545 ServRegs::eek:nAdd [CM113002] Registered: Ext.104
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  3. pepe75
    Sep 18, 2007
    Thanks for your reply, finally everything ok
    Co your help.
    Greetings
