Bypass Outgoing Message
Discussion in '3CX Phone System - General' started by swallservices, Jul 20, 2007.
  1. swallservices
    May 7, 2007
    6
    Dear All,
    I've been scouring the manual and the forums but can't seem to find an answer.
    When listening to the outgoing message on a specific extension is there a method of allowing the caller to skip the outgoing message and go straight to recording their message? I've been searching and searching but to no avail.
    Anyone?
    --Justin
