C# Call Control API MakeCall Help
Discussion in '3CX Phone System - General' started by vtech, Mar 8, 2011.
  1. vtech
    Mar 3, 2011
    Does anybody know what options you can put in the second parameter which can take a Dictionary<string, string> in the PBXConnection.MakeCall method? I was wondering if there is a way to specify the caller ID using that parameter, however, I can't find any documentation on this method that gives the available options to pass to it. Any and all help is appreciated.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    There is documentation for this method in source code, but neither NDoc nor Sand Castle generate it. At least I didn't find a way to enforce them to put it into the API documentation.
    In any case, this method is designed to serve very specific call scenarios and it doesn't provide requested functionality.
  3. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Can you expand on the "Very specific call scenarios" Stepan? Might help in an app we are writing for a customer
  4. vtech
    Mar 3, 2011
    Is there any way you could post the parameters that are available to pass to this method on this forum so we know what we have to work with? I appreciate your help.
  5. SY
    3CX Support
    Jan 26, 2007
    1,825
    it doesn't provide requested functionality. It is for sure.
    "Very specific call scenarios"="for internal use"
    If you develop applications then you should know about problems related to the situation when your application use "undocumented" functions.
    This method of PBXConnection object is not a "Wunderwaffe". It doesn't provide predictible and useful functionality...
