(c:x) Not Acceptable Here
Discussion in '3CX Phone System - General' started by evergreen, Apr 5, 2007.
  1. evergreen
    Nov 4, 2006
    5
    I have Welltech ip-phone 399, when i try to call other extension the log says (C:x)Not Acceptable Here
    I need an urgent help plz,,,
    Evergreen
  2. Anonymous
    Anonymous Guest
    Is this fixed yet?
    If not please provide a post with the log in it. (Is this your phone log or the 3cx server log)
    Also is your phone in the supported list?
    Henk
  3. NigelG
    Mar 29, 2007
    48
    THis may well be a codec problem, check the audio codecs you are using.
    Regards
    NigelG
