Call’s end unexpectedly with D-Link (unsupported)
Discussion in '3CX Phone System - General' started by Fritz.Kahn, Apr 1, 2008.
  1. Fritz.Kahn
    Feb 22, 2008
    14
    Hi Guy’s
    Please let me know if anyone has come across this and if it is a Software or Hardware issue, I currently have 3CX Sip server (free version) and a D-Link DVG-6008S VOIP Gateway. What is happening is when I make a call the call ends anywhere between 20 seconds and 10 minutes, it is very frustrating as call’s are being dropped every few seconds. If anyone has some sort of solution to this problem, please let me know.
    Thanx
    Fritz
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Re: Call’s end unexpectedly
    What kind of phones are you using?
  3. Fritz.Kahn
    Feb 22, 2008
    14
    Hi Archie
    It's D-Link DPH-120S x 7 and DPH-140S x 1, then I got two SIP-DECT cordless phones and two Ethernet phones (Not sure on the make). They all run off Ethernet ports and connect to a D-Link 1GB 16port switch.
    Hope this helps as all phones do the same thing.
    Thanx
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    No, it doesn't help because we didn't have experience with such phones. Could you provide some logs?
    Does it matter if call is ext-to-ext or ext-to-outside?
  5. Fritz.Kahn
    Feb 22, 2008
    14
    Hi Archie, thanx for your reply. These phones are South African phones, but it is only ext - outside (cellphone or lnad line)
    We are using a PSTN lines and not internet, the codec of 3CX, Voip gateway and phones are all the same, G729.A (I think this is right) is the one that is first priority. I have sent log's to D-Link in Taiwan hoping the designers can shed some light on the subject. But all I am trying to get an answer for is if I need to look at 3CX (If this is a know issue) or Voip gateway (Once again if it is a known issue using PSTN lines)
    Besides that Archie I am 100% happy with 3CX, of all the SIP software we tested 3CX is top's, from voice mail to digital receptionist...all works 100%, only snag is this dropping of call's.
    17:02:46 *** SLMON start to log ***
    17:02:56 [021102] == Ver(1.2.34.19.1782 2006/06/02 17:19:30) PId(085.DLinkBrTelefonica.Nortel.NoPrefix.drtp) Drv(0.9.4.57.55 13/Jul/2006 11:17:52) ==
    17:02:59 [021137] 9: 257895929999=OFFERING
    17:02:59 [021137] 9: Get CallerId=10001
    17:02:59 [021137] 9: Check Trunk FixLine
    17:02:59 [021137] 9: Hunting Trunk Line
    17:02:59 [021137] 2: Peer=192.168.123.4:7076, PT=0, RecvOnly=0
    17:02:59 [021137] 2: TrunkPrefix=, Dest=0720732443, Dialno=0720732443
    17:02:59 [021137] 2: FxoHookOff
    17:02:59 [021137] 2: SetInputGain(-2)
    17:02:59 [021137] 2: ==18:St_TrunkDialOut
    17:03:00 [021148] 2: DialOut(0720732443)=0
    17:03:02 [021165] 2: Fxo DialOut OK
    17:03:02 [021165] 9: 257895929999=ACCEPT
    17:03:02 [021166] 2: ==13:St_VoipAnswering
    17:03:02 [021167] 9: 257895929999=CONNECTED
    17:03:02 [021167] 2: RtpApiTalk[1,1], Peer=192.168.123.4:7076, PT=0, FC=2, NewOOB=1
    17:03:02 [021167] 2: ==14:St_Talking
    17:06:21 [023155] 2: Fxo Detected UDT Busy(0)
    17:06:21 [023155] DSP_ch2_check=0
    17:06:21 [023155] 2: FxoHookOn
    17:06:21 [023155] 2: Bye at Talking
    17:06:21 [023155] 2: ==15:St_PlayBusyTone
    17:06:21 [023156] DSP_ch2_check=0
    17:06:21 [023156] 2: FxoHookOn
    17:06:21 [023156] 2: ==3:St_Idle
    17:06:21 [023156] 2: SetInputGain(7)
    17:06:21 [023156] 2: SetFax(0)=0
    17:06:21 [023157] 9: 257895929999=DISCONNECT
    17:06:21 [023157] 9: Release Old Dlg #1
    17:07:42 *** SLMON start to log ***
    17:07:52 [024069] == Ver(1.2.34.19.1782 2006/06/02 17:19:30) PId(085.DLinkBrTelefonica.Nortel.NoPrefix.drtp) Drv(0.9.4.57.55 13/Jul/2006 11:17:52) ==
    17:07:54 [024083] 0: 10000=REGISTER
    17:07:54 [024088] 0: 10000=REGISTER_AUTHN
    17:07:55 [024092] 0: 10000=REGISTERED
    17:07:55 [024095] 1: 10001=REGISTER
    17:07:55 [024099] 2: 10002=REGISTER
    17:07:56 [024103] 1: 10001=REGISTER_AUTHN
    17:07:56 [024103] 3: 10003=REGISTER
    17:07:56 [024104] 2: 10002=REGISTER_AUTHN
    17:07:56 [024105] 1: 10001=REGISTERED
    17:07:56 [024106] 3: 10003=REGISTER_AUTHN
    17:07:57 [024111] 4: 10004=REGISTER
    17:07:57 [024111] 2: 10002=REGISTERED
    17:07:57 [024112] 3: 10003=REGISTERED
    17:07:58 [024122] 4: 10004=REGISTER_AUTHN
    17:07:58 [024123] 5: 10005=REGISTER
    17:07:58 [024129] 4: 10004=REGISTERED
    17:07:59 [024131] 5: 10005=REGISTER_AUTHN
    17:07:59 [024140] 5: 10005=REGISTERED
    17:08:00 [024143] 6: 10006=REGISTER
    17:08:00 [024144] 7: 10007=REGISTER
    17:08:00 [024146] 6: 10006=REGISTER_AUTHN
    17:08:00 [024148] 7: 10007=REGISTER_AUTHN
    17:08:00 [024149] 6: 10006=REGISTERED
    17:08:01 [024158] 7: 10007=REGISTERED
    17:09:59 [025333] 2: Fxo Detected UDT Busy(0)
    17:09:59 [025333] DSP_ch2_check=0
    17:09:59 [025333] 2: FxoHookOn
    17:09:59 [025333] 2: Bye at Talking
    17:09:59 [025334] 2: ==15:St_PlayBusyTone
    17:09:59 [025334] DSP_ch2_check=0
    17:09:59 [025334] 2: FxoHookOn
    17:09:59 [025334] 2: ==3:St_Idle
    17:09:59 [025334] 2: SetInputGain(7)
    17:09:59 [025334] 2: SetFax(0)=0
    17:09:59 [025335] 9: 257895929999=DISCONNECT
    17:09:59 [025335] 9: Release Old Dlg #1
    17:11:17 [026113] 9: 257895929999=OFFERING
    17:11:17 [026113] 9: Get CallerId=10001
    17:11:17 [026113] 9: Check Trunk FixLine
    17:11:17 [026113] 9: Hunting Trunk Line
    17:11:17 [026113] 2: Peer=192.168.123.4:7084, PT=0, RecvOnly=0
    17:11:17 [026113] 2: TrunkPrefix=, Dest=0720732443, Dialno=0720732443
    17:11:17 [026113] 2: FxoHookOff
    17:11:17 [026113] 2: SetInputGain(-2)
    17:11:17 [026113] 2: ==18:St_TrunkDialOut
    17:11:18 [026125] 2: DialOut(0720732443)=0
    17:11:20 [026142] 2: Fxo DialOut OK
    17:11:20 [026142] 9: 257895929999=ACCEPT
    17:11:20 [026143] 2: ==13:St_VoipAnswering
    17:11:20 [026144] 9: 257895929999=CONNECTED
    17:11:20 [026144] 2: RtpApiTalk[1,1], Peer=192.168.123.4:7084, PT=0, FC=2, NewOOB=1
    17:11:20 [026144] 2: ==14:St_Talking
    17:12:18 [026726] 2: Fxo Detected UDT Busy(0)
    17:12:18 [026726] DSP_ch2_check=0
    17:12:18 [026726] 2: FxoHookOn
    17:12:18 [026726] 2: Bye at Talking
    17:12:18 [026726] 2: ==15:St_PlayBusyTone
    17:12:18 [026726] 2: ==3:St_Idle
    17:12:18 [026726] 2: SetInputGain(7)
    17:12:18 [026726] 2: SetFax(0)=0
    17:12:18 [026727] 9: 257895929999=DISCONNECT
    17:12:18 [026727] 9: Release Old Dlg #1
    that is all I got, and as you can see it say's "CONNECTED"; "Talking", then "FXO Detect UDT Busy(0)"; "PlayBusyTone"
    Hope this helps.
    Thanx
  6. archie
    3CX Support
    Aug 18, 2006
    1,299
    First, free version of 3CX PBX doesn't provide G729 support
    Second, try to adjust tone/voice settings at Patton to your country. It seems it mistakingly recognise Busy tone in an audio conversation. Try to use another codecs also. Ask your Patton dealer to help in setting up Patton gateway.
  7. Fritz.Kahn
    Feb 22, 2008
    14
    Thanx Archie will try what you have mentioned above, are you able to tell me what codec the free version of 3CX uses as it's priority?
  8. archie
    3CX Support
    Aug 18, 2006
    1,299
    No. 3CX doesn't select codec (phones or gateways does), so it doesn't have any priority settings. Codec selection depends completely on negotiations between endpoins. (Yes, there're some exceptions, but I don't want to go deep in details).
  9. Fritz.Kahn
    Feb 22, 2008
    14
    Hi Archie
    No need and thank you for clearing up the codec issue. The problem is on the gateway with UDT setting's as it detects random pulses or noises as hangup tones.
    Thank you for all your help.
    Fritz
  10. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,939
    250
    You can not use those D-link gateways or phones. You must use supported hardware if you want to use 3CX
  11. sergey78
    Aug 11, 2010
    I have this problem.
    How to set UDT setting: what value to set in Low/High freq in #1, #2, #3, #4?
