Call a number from Internet browser
Discussion in 'CRM / Helpdesk / App Integration' started by Raman Kalia, Nov 22, 2017.
  1. Raman Kalia
    Jun 7, 2017
    14
    I would like to call any number on a website using 3CX windows soft client. How do I enable that. I could see people having same option for skype.
    Regards,
    Raman Kalia
  2. Mike Cartwright
    Jun 3, 2017
    26
    Hey Raman,
    What CRM or system of record are you currently using? You can enable click-to-call on any website via Tenfold.
    Tenfold is a CTI that can integrate 3CX with CRM (Salesforce, Netsuite, MS Dynamics, Zendesk, and more). One of Tenfold's key features is click-to-call. This feature converts all phone numbers inside the CRM or on any part of your browser into clickable hyperlinks. This can save you a lot of time and can eliminate the usual error of misdialing of phone numbers.
    You might want to check Tenfold out.
  3. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Do you know about the Chrome Extension - 3CX Click to Call?
    Also, you can enable a Hotkey from the 3CX Phone for Windows and not be limited by browser or even application.
