Call alert pop window behavior
Discussion in 'Ideas' started by solutionsit, Feb 4, 2016.
  1. solutionsit
    Nov 25, 2014
    62
    5
    This should user configurable whether the window is in the task bar or not.
    http://www.3cx.com/blog/voip-howto/call-alert-popup/
    See first comment in the comments at bottom of page.
