Call Assistant and Inbound Calls
Discussion in '3CX Phone System - General' started by BAd, Aug 17, 2009.
  1. BAd
    BAd
    Aug 17, 2009
    Hi!
    We're running the call assistant on our server in order to capture incoming calls. We've specified a command line executable in the options and selected all the relevant options.
    According to http://wiki.3cx.com/api/crm-api we should get notification when the call comes in, when it gets answered and when it ends. For some reason, the only notification we actually get is when the call is answered, which isn't much use to us. Is there any reason for this?
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Can you post the output of what your CRM is receiving from the Assistant?
