Call Assistant**Feat Request
Discussion in '3CX Phone System - General' started by rico06, Jul 29, 2010.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I suject to had on the setting of extension and show on the call assistant juste the localisation of the extension:
    like
    post 106 mike smith atlanta (or floor 4, or anything we like)
    and also, having the choice to show or not the extension not connect
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Re: Call Assistant
    Hi, yes please add this as a feature request.
    Thank and Regards.
  3. rico06
    rico06 New Member
    Jan 11, 2008
    143
    no interest ????????????
