Call Assistant language message
Discussion in '3CX Phone System - General' started by RobLloyd, Jul 25, 2007.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I did some changes to CA and didn't save it. When I went to exit CA I got a prompt in what I think is German.
    With two choices - Ja and Nein. I clicked Nein since I didn't want to save it but this should be fixed at some point.
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    what is the version of the 3cx phone system and what is the version of CA that you are using. Where you using english during this time in the 3cx management console when German suddenly popped up?
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    :oops:
    I didn't mean CA. It should have read 3cx softphone
    :oops:
    That's what you get for 5 hours sleep then working 15 hours!
    Terribly sorry about that. Won't happen again.
