call assistant: no calls show in "active calls" panel
Discussion in '3CX Phone System - General' started by aesteve, Nov 28, 2009.
  1. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    I was upgrade my 3CX phonesystem but not the assitant and i experience this problem. Installing the last assistant version, problem was solved.
  2. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    Hi Mattlandis,
    was the problem in the version ?
    Give us feed back.
