Call Assistant question
Discussion in '3CX Phone System - General' started by RobLloyd, Jul 31, 2007.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I'm using a licensed version of 3CX. I can't transfer a call to VM from it. I can transfer to another extension but not to VM. Option is not clickable... Is this not ready yet, not configured properly or is there something wrong with my license?
  2. Fynskisb16
    Jul 18, 2007
    21
    I'm not sure how it is unlocked when you purchase a version. Did you install the call assistant before you licensed you server? You might have redownload it and reinstall it using the licensed version.
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Thanks for the idea. Tried it but still had the same feature set. No VM transfer.
    Unless I'm doing something wrong.
  4. Fynskisb16
    Jul 18, 2007
    21
    Please post if you find out anything. I hope to have a licensed version soon. The features of call assistant will be handy.
