Call Assistant with V5
Discussion in '3CX Phone System - General' started by stevef, Dec 10, 2007.
  1. stevef
    Jul 20, 2007
    38
    Is the VoIP client supposed to replace Call Assistant?
    When using the Voip client in Desk Phone mode there is no option to transfer calls as with Call Assistant. This surely is the purpose of Desk Phone mode otherwise all you get is extension status stuff or am I missing something here.
    Our receptionist used Call Assistant to transfer incoming calls to extensions with V3. Can we still run Call Assistant with V5
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    i think you will find transfer function under the Action tab if u switch 3cx client to desk phone. Secondly Call Assistance is also available with V5 so need not to worry if yiu want to use call assistance please feel free to use it as well....
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    As bhavank says, yes, you can still use Callassistant.
    It is supposely the meaning that client are replacing the call assistant, but the feature is not yet active regarding transfer call.
    The client is still in beta, so i guess that it will come when released next week.
  4. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    The call transfer function appears to work in the version that I have (5.0.3763M.0)
    However
    The status lights do not seem to work have I missed something?
  5. Alan van der Vyver
    Nov 15, 2007
    15
    I saw something about the status lights not working in the free version. Is that what you have?
    regards,
    Alan.
  6. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    if you have gone through the details the FREE EDITION does not support the status function in 3cx client so status light will not be working under FREE EDITION. To get the status light working fine you need to get any of the paid version.
  7. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    OK thanks
    I hadn't got that far yet, thought it might be something that I had missed
  8. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    no a issue. If you want the extension status to be working you need to purchase the lisence for any of the paid version then it will be working great...
