Call assistant
Discussion in '3CX Phone System - General' started by Avilla, Jul 18, 2007.
  1. Avilla
    Jul 6, 2007
    9
    Hello everybody,
    I have a problem in getting call assistant running.
    Afer installation automatically the login page proposes the address of the server, but adding [1] at the end of IP address: xx.xxx.x.x[1] and, by loggin in, I get an error "server ureachable"
    Also deleting the [1] I get the same message
    On the other hand i have no problem to access the configuration console from the same machine.
    any suggestion ?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Do you enable the firewall at that machine?
  3. Anonymous
    Anonymous Guest
    What is your os? are you running IPV6?
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    http://www.pc-force.de:5481
    http://www.YourServer.TLD:5481
    try it this style
  5. Avilla
    Jul 6, 2007
    9
    Ok, this is clear and working.
    The problem is only in the connection from another PC where the call assistant is installed to the PBX
    I am running WinXP on the PC and Win2000server on the server where PBX is installed
  6. jits04
    May 2, 2007
    76
    Have you installed 3cx assistant on the same machine of 3cx pbx? You should avoid this.
    Please, install 3cx assistant on the machine where you need to manage the calls.
    or I didn't understand....
    regards
    William
  7. Avilla
    Jul 6, 2007
    9
    Sorry for the unclear explanation, here some more details.
    I have the PBX installed on our server.
    Then I have softphones installed on 10 pc connected to the server.
    I would like to have one of these PC with call assitant to act as the receptionist.
    So the problem is the "call assistant" that does not connect from the PC to the PBX on the server.
    Basically the firewall should not be a problem because the connection is inside our network.
    Maybe I have to specify a port, I use the 5060 but it does not work
  8. Anonymous
    Anonymous Guest
    Best way to go about it is:
    Fire up the 3cx Login page.
    Run the link on there to get call assistant
    Select install.
    for IP is (like mentioned before) [3cx server ip] minus the [1] or [2]
    Select an extension that is registered on the 3cx server eg 100 use that as login and password.
    And it should work from there.
