Call Barge in from Deskphone
Discussion in '3CX Phone System - General' started by aslampa, Apr 7, 2018.
  1. aslampa
    Mar 18, 2016
    45
    Is call barge in/listen can be initiated from desk phone? if what is the command for it
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,424
    187
    Hi aslampa,
    Is this a desktop telephone which is stand-alone or is it in CTI mode with 3CX softphone?
    Also what is the version of 3CX, deskphone brand, model and firmware version also?
  3. aslampa
    Mar 18, 2016
    45
    Its CTI with 3cx phone and work well when we initiate the barge in from soft phone.
    3CX V 15.5 Pro and Desk phones we use Fanvil X3S and Grand Stream GXP 1610/1620
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    There is not dial code for it, I think you have to use 3CX client or webclient
  5. aslampa
    Mar 18, 2016
    45
    I think it would be great feature more call centers interested in and 3CX will look in to this shortly
  6. eddv123
    Aug 15, 2017
    1,424
    187
    I would agree I think it is soft client only (but CTI is ok) request it as a feature request on the ideas site if you want it added.
  7. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    It is possible using a Call Flow Designer (CFD) and the 3CX Call Control API. However, how do you determine which call to barge into? The CFD would have to prompt you for the extension engaged in the call you want to barge into. For example, when you press the button, it would say something like "To barge into an active call, please enter the desired extension number". Naturally barge rights would still be enforced.
    jimbo59 likes this.
