Call between gataway
Discussion in '3CX Phone System - General' started by mcdamm, Sep 19, 2008.
  1. mcdamm
    Sep 19, 2008
    Is it posible to setup calls between to gateways,
    ex. call fram gateway 1 calls 0xxxxxxx
    Roul for Gateway 2, all calls start with 0 is routed to gateway 2
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello and welcome
    Yes you can, please more information to help you
  3. mcdamm
    Sep 19, 2008
    Hi, I'm testing the free version and I can not get it to work, gateway to gateway, is it posible i the free version.
    Morten
