Call by First Name
Discussion in '3CX Phone System - General' started by saltech, Jul 11, 2011.
  1. saltech
    Oct 9, 2009
    6
    Is there a way to make the call by name work by First name. At first I thought I could just switch last and first names, but the system prompt says "last name". is there a way to modify/custimize the prompt.
    TIA
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    You can modify the prompt if you want but Call by Name is still last name only. There is no way to change it to first name.
    I would suggest checking out http://3cx.ideascale.com/ to see if someone has suggested this already and then vote for it or if no one has, then you can add this feature request and have others vote for it as well.
    Thanks,
    Nate
  3. saltech
    Oct 9, 2009
    6
    How does one change the prompt that says "please enter the first three letters of the last name" to a custom message. If I can do that, then I can just use the ext users first name in the last name field and achiebe "call by first name"
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    Search the forums or read this threat - it will give idea how to change a voice prompt:
    http://www.3cx.com/blog/docs/localize-promptsets/
  5. paul1
    Jan 14, 2010
    80
    Once you find the promptset files you will see UserName.wav. This is the prompt to enter the first three letters of the last name.
    On my system this is the path:
    c:\ProgramData\3CX\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB\UserName.wav
  6. saltech
    Oct 9, 2009
    6
    thanks to all. This seemed to work.
  7. red45
    Nov 4, 2014
    62
    16
    Also see this thread for how to search both first and last names (which is the default of most other phone systems btw 3CX!):
    http://www.3cx.com/forums/call-by-name-using-first-name-34561.html
