Solved Call by name, extension not found
Discussion in '3CX Phone System - General' started by daveh82, Mar 20, 2017.
  1. daveh82
    Apr 25, 2012
    10
    Using the call by name feature, I get an "extension not found" reply when I dial the the corresponding 3 digits for the users last name. I have tested this on several extensions, am I missing a setting somewhere?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,343
    448
    Hello @daveh82
    Please note that for the call by name feature to work you need to record a personal identification message for the extensions you need to enable this feature. You can do this by calling the voicemail service and select 9 for options. It should be option 5. once you record a personal identification message try again and see if that works
  3. Alex Howard
    Apr 18, 2017
    17
    Is there a way to do this through the web client in 15.5? I am creating documentation for new users and so far they can do everything through the web client. It would be a shame to make them dial into their voicemail for this one thing.
    Alex
  4. StefanW
    Jun 2, 2009
    1,217
    89
  5. Alex Howard
    Apr 18, 2017
    17
    For anyone else wondering, so you don't have to watch a 10min video.
    Every user must have a personal identification recording.
    The personal identification recording can only be set by dialing into the voicemail. There is no way to set it through the web client.
    This information is relevant for V15.5
    Alex
    Gaucho713 likes this.
  6. Brett Coleman
    Jun 20, 2017
    27
    I would prefer if this was on by default for every extension with voicemail with an option to disable (by administrator only)
    hkgonra likes this.
