Call By Name in VAD
Discussion in 'CRM / Helpdesk / App Integration' started by brianlgrimm, Dec 6, 2011.
  1. brianlgrimm
    Dec 17, 2010
    19
    Is there any way to use Call By Name in a call-flow within VAD?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    No, that is a separated VXML script and can't be called from a VAD callflow. You would have to implement it yourself. Or transfer the call to a Digital Receptionist which implements it.
