"Call by Name" not working for an extension
Discussion in '3CX Phone System - General' started by Ben C, Jun 20, 2016.
  1. Ben C
    Oct 14, 2014
    71
    "Call by name" is not working for one extension (at least). It works for a few I tested.
    Last name is "Goodness" and when I press 466 (for Goo) on the phone, I get "extension not found".
    Any Idea what could be the reason?
    Thank you
    Ben
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Make sure the user has recorded his self-identification message through the voice mail. If the message is not recorded the call by name feature will not work.
    I just did a test in the office with the last name you provided us and i can confirm it works from a few different phones.
    You could also refer to the system manual link below, page 70 to review the correct procedure
    http://www.3cx.com/manual/3CXPhoneSystemManual14.pdf
  3. Ben C
    Oct 14, 2014
    71
    Yes, you are right.
    There is a last name Qu and adding the 0 after 78 didn't work. It works when I change the last name from Qu to Quu, but I will need his permission to do the change. Any suggestion?
    Thank you
  4. YiannisH_3CX
    May 10, 2016
    4,443
    282
    If you navigate to Troubleshooting>>Parameters and search for CALLBYNAME_MINLEN you will see the value of the parameter being set to 3.
    You can change that to 2 digits so it will match Qu as you want. But have in mind that this could cause some issues if you have surnames that match for the first 2 digits.
    Searching with 3 digits, limits the chances of the PBX matching wrong surnames.
  5. Ben C
    Oct 14, 2014
    71
    Thank you
