Call By Name
Discussion in '3CX Phone System - General' started by jpillow, Jan 30, 2012.
  1. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I'm having an issue with the Call by name option in the digital receptionist. When a caller dials a name they get the same error every time? "Extension not found" Has anyone else experienced this issue? If so what was the resolution if any? Thanks in advance for any assistance.
  2. efounco
    efounco New Member
    Sep 28, 2011
    148
    The user MUST record an identification message in the voicemail settings before the call by name feature works.
  3. jpillow
    Jun 20, 2011
    1,342
    That sound easy enough I will give it a try and let you know. Thanks!
  4. jpillow
    Jun 20, 2011
    1,342
    Worked perfect thanks!
