Call By Name
cbongard
We have a user who has a two letter last name. The Call By Name feature requires THREE letters. I have tested and the user cannot be reached through Call By Name.
Is there a solution to this?
check Advanced Settings - Customer Parameter
Search for "NAME"
CALLBYNAME_MINLEN Minimal length of number for call by name 3
CALLBYNAME_MAXLEN Maximal length of number for call by name -1
Excellent. That worked!
Now I'm looking for a way to fix the prompt. Currently the prompt says "first three letters...."
I found the prompt wav file that I could replace with one I record....but....the prompt is actually broken in to two wav files.
"Please Enter"+"the first three letters...."
So if I replace both, the "please enter" prompt that is used somewhere else would be my voice (male), with the default (female). That, unfortunately, would be a bit strange. I can re-record them all...but not something I REALLY want to do.
My question is then: is there a way to change the "Call by Name" prompt to only use ONE WAV file?
why not find a similar voice at fiverr.com and pay $5 for a pro recording...
Get 3CX - Absolutely Free!
3CX
