Call Centre Wallboard stats period and stuck calls.
Discussion in '3CX Phone System - General' started by concs, Dec 13, 2011.
  1. concs
    Apr 21, 2011
    29
    The wall board seems to continue to count stats until queue stats are manually reset. Is this the intended behavior?
    Is there any way to have the stats automatically reset on a daily basis?
    I am also seeing some calls under "Calls serviced now" that never go away. ie No operators on the phone and "Calls serviced now" = 2
    Is anyone else using the Wallboard having these problems?
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Regarding this problem "I am also seeing some calls under "Calls serviced now" that never go away. ie No operators on the phone and "Calls serviced now" = 2"
    Did you update 3CX Phonesystem to SP5?
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Regarding stats automatically reset on a daily basis,
    Submit your suggestion to...http://3cx.ideascale.com/
  4. concs
    Apr 21, 2011
    29
    Regarding SP5, yes uninstalled and reinstalled to SP4, same again for SP5..
    As for resetting stats, I will add to ideascale but I cannot see why anyone would prefer the current.
  5. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Hi, open a support ticket and put logs with the problematic call - we will take it from there.
    Thanks and regards.
