Call Control API & Call Flow Designer - Voicemails too
Discussion in 'CRM / Helpdesk / App Integration' started by kevinchamplin, Feb 13, 2018.
  1. kevinchamplin
    Feb 6, 2018
    7
    I have the Call Control API working like a champ. What I need to do now is if a call comes through I need to answer it and then do something. What's the best route to do this, i'm assuming I'll need to use the call flow designer to do this?
    Also I would like place a call (I have this covered) but then play the most recent voicemail once the user picks up. How do I access the voicemail data?
  2. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    891
    156
    Hey Kevin,
    Yes, when a call comes in, you forward the call to a CFD application. Your logic to "do something" is either in the CFD code, or in external code libraries called by the CFD.
    You can perform a MakeCall between a CFD application and an external phone number. In the CFD you handle your application logic including playing the specified voicemail which is simply a wav file.
    I don't know exactly what you are trying to accomplish, but this sounds a lot like our 3CX On Call Manager. Maybe we already have a solution for you.
  3. kevinchamplin
    Feb 6, 2018
    7
    that may accomplish what we need, i'll run it by management. Thanks
