Call Control API - Config server is not connected
Discussion in 'CRM / Helpdesk / App Integration' started by Waseem, Apr 21, 2017.
Tags:
  1. Waseem
    Mar 21, 2017
    16
    I am using the Call Control Api .Net library , i am using a free version 14 of 3CX, now not even sure if the API is meant to work with the free version
    When i try and use the connections settings i think i should be using [ConfService] (below) i keep getting the IsNotConnected exception.
    However when i use the values under [General] section , I can connect and MakeACall but any interaction with the PhoneSystem I get the Config server is not connected error.
    I was just messing about with the setting and somehow got it to connected and make a call but now can't do much beyond that.
    Just writing a simple program to test out first my .ini file looks as below
    Code:
    2[General]
    ;connection point to call manager
    ;used by:
    ;a) call manager initializes own listener before it connects to configuration server.
    ;b) components which are working directly with call manager
    ;MUST NOT be used by components which make connection to configuration server.
    ;They MUST use CM_API_IP, CM_API_PORT, CM_API_USER and CM_API_PASSWORD paramaeters to make direct connection to CallManagerAPI
    pbxSLNIC=127.0.0.1
    cmPort=5482
    pbxuser=instance_instance127750
    pbxpass=42ov2rvu16n
    AppPath=C:\Program Files\3CX Phone System\Instance1
    AppDataPath=C:\ProgramData\3CX\Instance1
    Tenant=instance1
    [ConfService]
    ;connection point to configuration server for components
    confNIC=127.0.0.1
    ConfPort=5485
    confUser=cfguser_default
    confPass=pwhshhlew3va
    PhoneSystem.ApplicationName = "UniqueName"
    [CfgServerProfile]
    ;configuration server connection to database
    ;exclusively used by configuration server
    DBHost=127.0.0.1
    DBPort=5480
    MasterDBUser=phonesystem
    MasterDBPassword=Uoi5CIvezBEwTJ
    MasterTable=phonesystem_mastertable
    DefFile=Objects.cls
    [QMDatabase]
    DBHost=127.0.0.1
    DBPort=5480
    DBName=database_single
    dbUser=logsreader_single
    dbPassword=47z7x0tco5hs
    [MIME_TYPES]
    MESSAGE=x-chat/control
    My .NET code is below , note the connection if working OFF the Default values from my testing it cannot pick up CM_API_IP etc from the system.
    So the code below works fine and makes the call ..
    if i uncomment this line DN dn = PhoneSystem.Root.GetDNByNumber("852"); the call is still made but in the console an exception is thrown and I cannot do other things i want to .
    Any ideas at all...
    Code:
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    using System.Threading.Tasks;
    using TCX.Configuration;
    using TCX.PBXAPI;
    namespace _3cxTest
        class Program
            static void Main(string[] args)
                PBXConnection pbx = CreatePbxConn();
                try
                    pbx.MakeCall("852", "12");
                  //  DN dn = PhoneSystem.Root.GetDNByNumber("852");
                catch (Exception e)
                    System.Console.WriteLine(e.ToString());
            public static TCX.PBXAPI.PBXConnection CreatePbxConn(string host, int port, string user, string password)
                return new TCX.PBXAPI.PBXConnection(host, port, user, password);
                // return new TCX.PBXAPI.PBXConnection("127.0.0.1", 5482, "instance_instance127750", "42ov2rvu16n");
            public static TCX.PBXAPI.PBXConnection CreatePbxConn()
                //v14 (cloud and in premiss) - stores pbx API connection parameters in configuration.
                //ini file is not required to obtain this information.
                bool exists = false;
               /// return new TCX.PBXAPI.PBXConnection("127.0.0.1", 5485, "cfguser_default", "pwhshhlew3va");
                return CreatePbxConn(
                    GetParameterValue("CM_API_IP", "127.0.0.1", ref exists),
                    int.Parse(GetParameterValue("CM_API_PORT", "5482", ref exists)),
                    GetParameterValue("CM_API_USER", "instance_instance127750", ref exists),
                    GetParameterValue("CM_API_PASSWORD", "42ov2rvu16n", ref exists));
            public static string GetParameterValue(string name, string DefaultValue, ref bool exists)
                try
                    exists = true;
                    return TCX.Configuration.PhoneSystem.Root.GetParameterByName(name).Value;
                catch
                    exists = false;
                    return DefaultValue;
  2. Waseem
    Mar 21, 2017
    16
    Update to this , the code is not throwing an exception after i added this , not sure if it solves my overall problem
    Code:
      PhoneSystem.ApplicationName = "UNIQUENAME";
                    PhoneSystem.CfgServerHost = "127.0.0.1";
                    PhoneSystem.CfgServerPort = 5485;
                    PhoneSystem.CfgServerUser = "cfguser_default";
                    PhoneSystem.CfgServerPassword = "pwhshhlew3va";
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,609
    126
    Hi @Waseem,
    That's what you had to add, the connection settings to the API knows where it has to connect, user name, password, etc. After that it should work. Please let me know if you're having any issue after adding the connection settings.
    Kind regards.
    Waseem likes this.
  4. Waseem
    Mar 21, 2017
    16
    @edossantos
    Thanks for the help ... I have managed to get some progress with the above.
    I am now having the following problem:
    In an ideal world i would like to invoke various things via a web service thus i can call it form a web application (coded in php , or whatever) .
    If i create a .Net 3.5 web service application and include the DLL i downloaded from here (for V14) (https://www.3cx.com/blog/docs/call-control-api/) . It doesn't work as the assembly is complied in .net 4 (so it says)
    Trying to build a web api mvc style solution gives other errors like the assembly is not found (which i can try and resolve but haven't so far )
    Any ideas ?
  5. edossantos
    Jun 27, 2007
    1,609
    126
    Hi @Waseem,
    Why do you create a .NET 3.5 project? That's very old, you should work with a modern version, I would suggest 4.6 and greater. You shouldn't have any issue using that version.
    Kind regards.
  6. Waseem
    Mar 21, 2017
    16
    Thanks @edossantos
    This page describes 100% the problem i am having , the .NET 3.5 was a desperate attempt to get something working as i was hitting a brick wall.
    http://www.toughdev.com/content/2013/01/using-3cx-call-control-api-in-a-net-application/
    This guys solution was to use WCF , is there any way of using a standard API app , i have tried everything , i get the same error as described above for , API, MVC solutions I have it working via a DLL and using VAD but i need an web interface too.
  7. Waseem
    Mar 21, 2017
    16
    I solved this problem by hosting the API on Abyss web server the same one that my 3CX was running on , there were no problems at all.
    You have to just change the port setting the abyss config file to get access to the console and then set up a new website ..
    Details of how to get to the console are here :
    https://www.3cx.com/blog/docs/https-3cx-abyss/
    Hope this might save someone lots of time
  8. edossantos
    Jun 27, 2007
    1,609
    126
    Hi @Waseem,
    Glad to hear that you have solved it. Using the same web server fixes the issue because the DLLs are already loaded in memory...
    Also, I think that the problem in the article described is that you were missing a dependency DLL. First, if you get this error:
    System.BadImageFormatException: Could not load file or assembly ‘3cxpscomcpp2.dll’ or one of its dependencies. An attempt was made to load a program with an incorrect format
    That means that your project is x86 and the DLL is x64. Please note that 3CX is a 64 bits app, so please ensure that your program running the 3CX Call Control API is also a 64 bits app.
    Then, if you get this error:
    Could not load file or assembly ‘3cxpscomcpp2′ or one of its dependencies. Modules which are not in the manifest were streamed in. (Exception from HRESULT: 0x80131043)
    That means that the DLL or one of the dependencies are missing. This is usually caused by a dependency, as you know that you need to copy the file "3cxpscomcpp2.dll" to your working directory. The dependencies are 2 libraries:
    - sl.dll (this is mentioned in the article you posted)
    - tcxpscom_native.dll (pretty sure the missing DLL)
    Kind regards.
  9. Hardik Soni
    May 22, 2017
    19
    When i run your sample example at time error will occured in var dns = PhoneSystem.Root.GetDN();
    Like==>": Unable to load DLL 'tcxpscom_native': The specified module could not be found "
    Can you please help me????
  10. копал
    Jun 6, 2017
    никак неполучается вклчить мжно какйнибудь тел для связи чтобы обьеснить как все работает спасибо
  11. dem23step
    Jul 22, 2017
    Hi @Waseem, can you explain please what do the values "852" and "12" stand for?
    Code:
  12. dem23step
    Jul 22, 2017
    @edossantos, can I ask you too?
  13. edossantos
    Jun 27, 2007
    1,609
    126
    It's from and to numbers.
  14. Rajthilak
    Aug 23, 2017
    5
    hi,
    I'm using v15, Please send me the code that how to make call from a New Windows form
  15. Rajthilak
    Aug 23, 2017
    5
    I can able to call now using MakeCall method.
    But now i need to redirect some url after call ends.
    For example: After my call ends in my softphone, website like https://www.3cx.com should open in browser.
    How can i identify in v15 Call Control API. Please help
  16. Andreas Paradisiotis
    Apr 7, 2017
    53
    12
    Hello Rajthilak
    One way to do it is to monitor the connection status of the call from active connection's.
  17. edossantos
    Jun 27, 2007
    1,609
    126
  18. Rajthilak
    Aug 23, 2017
    5
    Ok Noted with thanks
