Call Control API - Linux
Discussion in 'CRM / Helpdesk / App Integration' started by Adam Wride, Jul 31, 2017.
  1. Adam Wride
    Jul 28, 2017
    8
    Is the call control API available on a linux server - if so, can someone give me a clue as to how I can get it working.
    We need to be able to create a URL that can make a call as we are working on a reception app at the moment on an android tablet.
    Have tried creating a core web api in .NET to host on linux but the 3cx dll does not appear to be able to work with a .net core.
    Please help, holding up some of our projects at the moment.
    Thanks in advance
    Adam
